How do you identify an Andrews cam?
I pulled the cam out of my 76 shovel today. It measures .450 lift, but the only number on it is 1843 (I think) stamped on the back of the gear. Andrews web site doesn't reference anything with this number, either as a part number or timing. Anyone recognize it?
Edited to add that i went back over to the shop after taking a break, and found the grind stamped on the inner end of the shaft. It's an A grind. Sorry about that.
All Andrews Cams I have seen have been like this!! FWIW
BTW I would Trade a Good, Early model, "B" for a number one!!
the lobe type on a camshaft is only proportional in size to the rocker ratio
the lower the ratio as in a shovel 1.43 to 1 the cam lobe needs to be larger to get the same affect as an evo cam that has a ratio of 1.626 as those lobes are way smaller in size
in practice - a cam lobe that measures with a dial gague - .350 X 1.43 has a lift of .497 the same lobe lift .350 X 1.625 has a lift of .56875
what you see as aggressive is the duration but the lifter rollers are different sizes small on the shovel and large rollers on the evo lifters its all in the mechanics of it
andrews, cam, cams, camshafts, davidson, evo, harley, identifing, identify, identifying, shovelhead, stamped, timing
