rear head removal 1979 shovel
"Make sure the piston is all the way down , if its at the top head will hang on it and yah it's that close"<-------What he said!
I had a '80 model that the top of the cylinder was just a c-hair too tall to get the head out of the frame. Finally just pulled the motor. It was the root cause of the rear head blowing the head gasket. Once it was shaved, no more blown gaskets.
Get the metal wafer gaskets man DO NOT use the old paper style if you can avoid it . The new ones are install dry and forget them . Even on the old paper gaskets any sealer is a bad idea it weakens the gasket and you get deformation after you torque and run the motor a few times , recheck the nuts you'll find them loose again .
I was going through the old style about every 2 or 3 years haven't changed another since I went the new ones . A dab of blue loctite on the box studs , torque & let sit overnight and your good to go .
Rear Head Removal 79 Shovelhead
Last night I ran into this very issue same year Shovel (mine is an 4-speed FXE kick & electric, rotary top btw), also an 80 incher with S&S jugs, rods & wheels in original stock frame & HD cases with matching serial numbers; and did some googling and found this thread...
I found a work around that did not require the engine removal that I thought it would after reading this last night...
On mine, I found that if I removed the first 3 rocker box nuts, front to back on the primary side... that gave me the c***-hair more room to get the rear one off without removing the engine...
big sigh of relief...
Maybe obvious to some, not so obvious to others, hoping it will save somebody a engine removal in the future just to change a fricking gasket.
FWIW The HD OEM Manual is the ONLY manual worth a nickel for this bike and it is greatly lacking in need to know info, makes way too many assumptions that whomever is working on the bike is a former or current HD factory employee... IMHO
