Notices
Pics of changing out the damping ring spacer.
Old 07-14-2019, 04:39 PM
470004's Avatar
470004
470004 is offline
Thanks for the photos.
Old 07-14-2019, 07:25 PM
RIPSAW's Avatar
RIPSAW
RIPSAW is offline
Originally Posted by Max Headflow View Post
As mentioned it is simply a spacer. The Belleville spring is about 0.030 thick, and maybe 0.100 high (should have measured). The friction disc is about 0.148 thick.. With the spring sitting on the spacer, you got say 0.063 + 0.100 height so as the clutch is let out the spring/spacer start pressing the clutch stack together causing it to drag for say the last 0.163 (spring and spacer) - 0.148 (friction) = 0.015 thou.. Increasing the spacer causes the clutch to start dragging another about 0.016" earlier or 0.031".
Trying to get a handle on the engineering on this. Is this set up do to the hydraulic clutch or the nature of the recluse clutch (sorry if i did not spell it correctly)
I thought the damper was Bellville and its purpose was to brake the rear disk straight so it did not bind since I assumed the actual clutch diaphragm spring flattened it.
In your first pictures, is that a seal on the clutch pushrod? How come Harley is having do much problem with that?
Is there a diaphragm spring plus those 3 coils?
Old 07-14-2019, 08:33 PM
mikes300's Avatar
mikes300
mikes300 is offline
Rekluse? This is the stock clutch. The seal disc in yuestion is only on the newer bike and is on the trans side
Old 07-14-2019, 09:02 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 1,023 Likes on 852 Posts
This clutch is not specific to any part of the hydraulic clutch or a recluse. It's called a Slip Assist clutch. If you look closely you will see that there are 3 ramps between pressure plate and inner clutch hub. Theses ramps assist in the clamping action of the springs which allow a lighter spring to be used and lighter clutch pull. You can see the ramps and notice that the outside pressure plate actually carries one of the steel plates. As the plates clamp, the outer steel causes the outer pressure plate to rotate, increasing clamping pressure. IMO, the pressure plate rotating clearance is what makes these new clutches clunk.
The slip /assist design really has nothing to do with the small belleville damper spring tho IMO the slip/assist narrows the friction zone some. Increasing the thickness of the spacer widens the friction zone some. It could have also been changed by changing the Belleville spring but it was probably cheaper to change the spacer.
Here is Yamaha's version of slip assist..
Not sure what you are trying to describe as for the purpose of the small Belleville spring but it's purpose it to engage the clutch slowly / gradually. In doing so it can keep the clutch from chattering. It occupies the space next to the first clutch plate and does not do anything to the plate. With the clutch fully engaged, the inner friction is compressed between the inner part of the hub and steel plate right next to it. This damper function is pretty much the same on every big twin HD clutch since 1998.
This clutch does not have a diaphragm spring like the TC regular clutches. It has the 3 spring and the assist feature. The new softails have the same clutch but use clutch cable. I'm not sure where you see a seal. There isn't one in any of the pics. Center of the clutch pressure plate holds the throwout bearing instead of an adjuster which different than cable operated bikes. The oil transfer issue is a completely different discussion in itself.
Old Yesterday, 05:34 AM
RIPSAW's Avatar
RIPSAW
RIPSAW is offline
This is what I first thought I was looking at..
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
