2018+ Softail Models Breakout
2019 Low Rider Initial 50-miles Assessment
Old 07-13-2019, 08:13 AM
Las Vegas Jim's Avatar
Las Vegas Jim
Las Vegas Jim is offline
I wasn't issued a standard size body at birth. Short legs & arms and a long body. So, I have fit problems on everything I buy.
Old 07-13-2019, 08:21 AM
Las Vegas Jim
Yes, but it isn't the standard size extension cable. Dealer ordered in the standard size, and it was way too long. The next size shorter extension cable fits really well. If you get the 4" riser, make sure your dealer does its homework and orders in the correct length cables.
I love the risers. I like the stock handle bars, and the 4" bent-back riser gives me 2" more up and 2" more back. This position puts me in a relaxed arm extension position, and I have good control stop-to-stop of the handlebars. FYI: I have s 31" sleeve length.
Old 07-13-2019, 05:19 PM
Justarider22's Avatar
Justarider22
Justarider22 is offline
Stage II
I have the same bike with a few mods.
Anyone have a handlebar solution?
The executive who pencil whipped it should only be allowed to use that bar on all his bikes from now on.
Old 07-13-2019, 05:32 PM
Jehu's Avatar
Jehu
Jehu is offline
Received 1,073 Likes on 609 Posts
I assume you were OK with the throttle position wires but just needed the clutch cable extension. If, by any chance, you could post and/or PM me the part number of the clutch cable extension you found worked properly - please let me know as my riser are inbound.
Old 07-13-2019, 07:07 PM
Las Vegas Jim
NO, the dealer didn't give me the part number. FYI the front brake cable also had to be extended.
Old 07-13-2019, 07:44 PM
Justarider22
Stage II
That's a bummer
Thinking the sport glide handlebars might be perfect for a lowrider
Old 07-14-2019, 06:22 PM
Las Vegas Jim
So much goes into creating a bike that "feels" right--starting with "where" and "how" you ride. Besides the obvious accommodating physical characteristics, the interaction between the various components can rapidly change the feel of any one component. I like the stock handlebars that came on the Low Rider, but I didn't like where they were positioned relative to my arm length (reach) and height (prefer an upright sitting position). If you are going to the expense of replacing the stock handlebars, spend some time exploring what feels the best, not just looks right. I am sure that whatever you do, you will be much happier in the long-run if you get the right feel.
Good luck.
Old 07-15-2019, 05:54 AM
OldMike's Avatar
OldMike
OldMike is online now
Received 1,828 Likes on 1,209 Posts
Originally Posted by Justarider22
That's a bummer
Did somebody say the Sport Glide bars won't work?
This post is confusing to me, maybe try starting a new thread with your question.
Old 07-15-2019, 07:49 AM
slw210's Avatar
slw210
slw210 is offline
Originally Posted by Mchad
Likely some obscure motor vehicle regulation says tags must be mounted a certain way...
Other manufacturers similar fender bikes have them under the taillights, etc. I still like the laydown plates, but still, those uprights are flat out dangerous.
Mchad
81
11-10-2021 08:16 AM
Las Vegas Jim
21
07-04-2019 08:20 PM
Wampa Stomper
06-30-2015 02:58 PM
Mcfire12
06-19-2014 07:13 AM
ghira75
06-16-2012 01:29 AM
Quick Reply: 2019 Low Rider Initial 50-miles Assessment
