2016 new Bolt on 110 kit
(copied from that item description)
-----Fits 50-state ’11-later DynaŽ FXD, FXDB and FXDC models equipped with Shorty Dual Exhaust. Installation requires separate purchase of Muffler P/N 64895-09 (Qty 2). Also fits 50-state ’10-later FXDF and FXDWG models. FXDF and FXDWG models requires separate purchase of Mufflers P/N 65884-09 and 65886-09. All DynaŽ models require separate purchase of Screamin’ Eagle high flow cleaner. ’10-’11 DynaŽ models require ACR Harness P/N 70623-06. Does not fit models with engine cases that have been machined to accept large-bore cylinders. Also fits 50-state ’11-later SoftailŽ models (except FLS, FLSS, FLSTFBS, FLSTN, FLSTSB, CVO™ 110 models or models with engine cases that have been machined to accept large-bore cylinders.). Requires separate purchase of Screamin’ Eagle high flow air cleaner. ’11 SoftailŽ models require ACR Harness P/N 70623-11.------
Little confusing wording, but sounds like some models need cases bored, some don't..... My guess is all do... But I don't know.
My understanding of cubic inches is you only get more with larger bore and Pistons, OR, longer stroke. Longer stroke cannot be obtained without crankshaft work, so bigger jugs and bigger pistons is all this is talking about.
Again, my understanding of the stock HD cases was 107 was the largest possible without case boring....
Something seems wrong here to me...
In order to yeild 110", on top of the 4 3/8" stroke, it has to be a 4" piston.
NO WAY, SHAPE, OR FORM can that be done w/o boring the cases, regardless what is said in that advertisement.
3.937" bore is the limit, at 107".
Scott
Scott
__________________
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Maxton Mile World Record
4500 sq ft. facility
See us on Facebook.
Crank Rebuilding
See us on Facebook.
