General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Need to have my frame welded. Rather than strip the whole bike down I can remove the bags and rear fender to do it. Question is do I need to disconnect the battery and or remove fuses for any reason
I would disconnect the battery as well as unplugging the ECM. I have seen sensitive electronics ruined as well as crank bearings fused to cranks on heavy equipment making for costly repairs. Keeping the welder's ground as close to the work as possible will pretty much eliminate any issues but why take a chance when these precautions are quick and simple to do.
Several good suggestions above ... Remove/unhook the battery. Good clean ground close to your welding point. Cover everything with a heavy material near/around the area to avoid damage. Use a well ventilated area ( consider the sparks and fuel ).
