How dirty should primary oil be?
Old 04-16-2016, 10:10 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,273 Likes on 11,143 Posts
Default How dirty should primary oil be?
I have my primary open to install a SE Clutch Diaphram Spring. I have 3.5K miles since my last dealer service where they were supposed to have changed out the primary with Formula+. I guess that since the primary is isolated from combustion, I though the old would be relatively clean, after just 3.5K miles. But, per the picture below, it is an ugly shade of black. Not that I have anything against black....I just didn'to expect it to be this black.
So, experts of things oil, what says you? Does my Formula+ look normal for 3.5K miles?
Old 04-16-2016, 10:29 AM
Imold's Avatar
Imold
Imold is offline
another old guy
Received 4,614 Likes on 2,726 Posts
I've never seen black oil from a Harley primary, usually pretty clean. Might not look so black if it was in a glass jar with light shining through, though. Makes me wonder, did you do the previous oil change yourself, or have a dealer do it - if they did...
Old 04-16-2016, 12:44 PM
TriGeezer's Avatar
TriGeezer
yup..always had the dealer do it, and at each 5K service. Yeah...I'm wondering about what else they fast tracked...
Old 04-16-2016, 12:45 PM
TriGeezer's Avatar
TriGeezer
Oh yeah...and the bike only has 18,000 miles.
Old 04-16-2016, 04:31 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Probably doesn't need to be said, but a visual gives you no indication of the quality, service life, or "dirtiness" of an oil; unless of course you can see solid contaminants such as metal parts or something. If you suspect something is awry, have an oil analysis done. If you suspect foul play by the dealer, call them out in it. I know not everyone has the same capabilities, but this is one reason I enjoy doing my own work...avoiding shenanigans. No one touches my bike for any type of service I can do.
Old 04-16-2016, 04:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,497 Likes on 4,612 Posts
There is no reason to suspect the dealer did not change the primary lube.
It gets dirty.
Does the owners manual say to change the primary lube every 5k on the Tri Glide?
Old 04-16-2016, 05:00 PM
skid_pimp's Avatar
skid_pimp
skid_pimp is offline
As the clutch wears the oil gets dirty, it is what it is
Old 04-17-2016, 12:05 AM
TriGeezer's Avatar
TriGeezer
No, its the same as the other 103 motors. But, it's included in the astronomical price the dealer charges for each 5k. And I'm ok with it being changed at that frequency.
Well that was profound! Thanks I didnt realize that (sarcasm). My question regarded my perception that it seemed ecessively dark for only 3K miles.
Old 04-17-2016, 01:19 AM
1Canuck's Avatar
1Canuck
1Canuck is offline
Received 2,252 Likes on 1,439 Posts
IMO the oil turns black from heat. It may only take 1K to turn black.
Old 04-17-2016, 07:08 AM
skid_pimp's Avatar
skid_pimp
Ok I'll explain further. Yes that is normal, it can and will turn black in as early as 500-1000 miles especially in heavy city traffic, in heavy scooter applications such as a trike, or in racing applications. Between clutch material, and heat, it will discolor very quickly. I know this because my bikes are often used to teach maintenance lessons to my Soldiers, so I do my maintenance on schedule as well as at completely random times, sometimes at very low mileage, comparing the differences of the various HD lines. Yes I go through some extra oil, and gaskets, but every time I move, I leave capable wrenches in my wake, and that is an acceptable cost for me.
Quick Reply: How dirty should primary oil be?
