Harley volt gauge calibration.
I'm sure some of you already know about this, but I did a search online to find out if someone could calibrate a volt meter in a ultra classic. I even called the dealer and they said no, this is not true! I bought a new volt gauge for my 06 ultra and it was reading 15.5 volts but it only had 13.7 going into the gauge, that's when I called Harley and did my online search. ( nothing). Noticed an adjustable diode or something like a diode just inside a hole on the side of the gauge. Using my old gauge I plugged it into the bike , fired it up and turned the screw. The needle will move higher or lower depending on the direction you turn the screw. So there you go, if you voltage is not reading right, just slightly turn the screw inside the hole on the side of the gauge and set it to what you are reading on your meter. Hope this helps someone as it saved me from making another trip to Harley.
The following 8 users liked this post by SGT DNG:
cficole (01-18-2018),
Frank the Real Biker (02-28-2018),
Hey Man (12-23-2016),
heybaylor (12-23-2016),
mctraveler (01-16-2018),
and 3 others liked this post.
Thanks for posting that info. The reason for this forum is clearly stated in the first four words of your last sentence.
SGT DNG (12-23-2016)
Received 4,281 Likes
Sorry, not sure how to get to that section of the forum. I'm new to this forum, and there is so much stuff crammed on the home page it kind of hard to figure out. Just not what I'm used to.
