Riser bushings
Riser bushings
Just bought a used switchback, with 16" apes, quality job installing them obviously, but they used the stock bushings. I know I'm not going to die by riding the bike like that, but they are a bit sloppy.
Any of you guys have tall bars with stock bushings? Any pro's or con's to having stock vs poly bushings?
I'm no rookie, just never installed apes in the past without changing out bushings.
Thanks!
Thanks!
Hey no-rookie, I had 16s on my street bob with stock bushings. Really didn't bother me any. Everyone told me to upgrade the riser bushings but I didn't bother. There was a little more movement in the bars than before but nothin I would worry about.
Received 1,934 Likes
Due to other mods, I had to swap from stock bushings to solid metal 10 degree angled ones with my 14" apes. These are understandably a rock solid mount and vibration isn't an issue, though I do have a "B" motor in my BO. Only downside is price:
https://www.denniskirk.com/la-choppe...prd/598833.sku
If you don't need em angled, they're substantially cheaper.
Have a read of these threads it might help to decide.
https://www.hdforums.com/forum/softa...ings-help.html
https://www.hdforums.com/forum/dyna-...treet-bob.html
Received 2,189 Likes
I am running LA choppers solid bushings as well. Absolutely no play in the bars. A buddy of mine has a 2010 SuperGlide which he used the stock rubber bushings on his 16" install. They were obviously worn and had a bunch of slop and play. I told him to go either poly or metal and he went poly. He is happy with it now.
Just wanted to update the crowd, or in case someone else searches for this topic. The poly bushings did the trick, those bars hardly budge!
28-30ft lbs torque by manual for the riser bolts in case anyone needs the info.
Tricky to do with that road king like front nacelle, but easy enough job I suppose. Thanks for all the advice!
