FLH triple tree repair
Old 04-27-2017, 11:20 PM
McCutcheon44's Avatar
McCutcheon44
McCutcheon44 is offline
Default FLH triple tree repair
Does anyone know if there is a replacement stem available for early FLH triple trees and who sells them if so?
I have searched for several hours but have came up with nothing.
Thanks,
Gregg
Old 04-28-2017, 02:02 AM
CRASH69's Avatar
CRASH69
CRASH69 is offline
Year? V twin has all that hard to find stuff J@P cycles sells V twin or you can search Ebay everyday till one pops up, tomorrow I will post a part number out of my catalog when you post the year...
Old 04-28-2017, 02:54 AM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
You could check with a machine shop if all else fails. It could be pricey.
Old 04-28-2017, 09:13 AM
McCutcheon44
It's a 1975.
I have searched JP, V twin, Vulcan and several others but have only found
Springer and XL replacement stems.
I bought an Ebay aftermarket lower triple tree that I was going to use but it looks like sh_t to me. I thought about cutting the stem out
of it and tigging into mine but it seems like a waste.
I own a small Atlas Lathe but don't know how to cut threads!
Thank you,
Gregg
Old 04-28-2017, 11:03 PM
CRASH69's Avatar
CRASH69
CRASH69 is offline
I gave it my best shot the only one I found is the one you found for the springer, its listed for shovelhead give them a call... https://www.yalesmotorcycleparts.com...rees-and-parts
McCutcheon44 (04-29-2017)
Old 08-13-2017, 04:30 PM
McCutcheon44
Default Triple Tree repair
I thought I finally had this all ready to weld back together but when I mocked it up to set the height of the stem I noticed the angle of the stem is back at the top quite a bit.
Now I wonder if my upper triple tree is compatible with the lower, I'm afraid it may pull to much rake out of the forks.
Does someone out there know if the upper and lower trees in the photos are good together? I took picture of the OEM part numbers.
Attached Thumbnails FLH triple tree repair-img_1458.jpg   FLH triple tree repair-img_1459.jpg   FLH triple tree repair-img_1460.jpg
shizzomynizzo
06-23-2014 07:50 AM
bigdog8040
04-08-2014 02:20 PM
82flh
10-28-2012 01:24 PM
Skydive D-4107
Shovelhead
01-17-2012 02:28 PM
antoniov1
10-09-2006 04:05 PM
Quick Reply: FLH triple tree repair
