Installed Electra Glo LED Saddlebag Lights
Old 05-19-2017, 07:34 PM
cptdenny's Avatar
cptdenny
cptdenny is offline
Default Installed Electra Glo LED Saddlebag Lights
I installed these saddle bag lights myself. I chose the smoke lens to match the other rear smoke lens LED lights on my 2015 Road Glide CVO.
Run/Brake/Turn Lamp-Chrome Housing/Smoked Lens-67800-451A
$187 +$5 shipping. From Broadtracker.
Old 05-19-2017, 08:01 PM
talkingrock's Avatar
talkingrock
talkingrock is offline
I put those on my 2016 SGS they look and work great plus added visibility
Old 05-19-2017, 08:08 PM
15_MG_SG's Avatar
15_MG_SG
15_MG_SG is offline
Looks good lights up the back nice like the smoke lenses.
Old 05-19-2017, 08:21 PM
twosailin's Avatar
twosailin
twosailin is offline
Looks great! I had a set on my 2014 and now my 2016. The ones on my '14 lasted over two years. The ones on my '16 lasted five months. The left side began flickering. The plug pins were corroded and would NOT be covered under the year warranty! My dealer would replace the six pins charging a half hour labor for each of the six pins. A cost of $300 for something that cost about $200 originally. I fixed it myself. As much as I like these I will not be buying HD ones next time! There are other lights now being sold for this purpose.
Old 05-19-2017, 08:27 PM
muddmann's Avatar
muddmann
muddmann is offline
Looks GREAT!!!!!!!
Old 05-19-2017, 08:45 PM
Harttoo's Avatar
Harttoo
Harttoo is offline
Had them on My 2014 for 35000 miles.Pulled them and installed on My 2017 using 3M double sided tape.Still look and work great.
Old 05-20-2017, 03:08 AM
PopsHD's Avatar
PopsHD
PopsHD is offline
I've had them since they were available. I wanted more light and these did the trick. I have a friend with a '17 CVO Limited. I'm trying to talk him into adding these as well. The smoke lens look good but is not as bright as the red when just in run mode, IMO.
Old 05-20-2017, 07:29 AM
Frank the Real Biker's Avatar
Frank the Real Biker is offline
Mine began flickering just 3 weeks before the warranty ran out. I rode to the dealer and showed it to them. Dealer replaced them for me. They didn't look at the connections or anything. After some further research I was told to give the connections a good dose of dielectric grease...which I did. Almost two years later and they still work fine. The grease keeps dirt out and helps eliminate corrosion.
YMMV
Old 05-20-2017, 03:36 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
Back in 1973 I was hit from behind while on a motorcycle, the Electra Glo Saddlebag lights
were a must on my Bike. I also added a Run & Brake light on my Tri Bar fender light too.
When I stop I want the Cages to know, at 71 I'm a heal slower, and don't want this Bike totaled.
John
Old 05-21-2017, 07:53 PM
twosailin's Avatar
twosailin
.Frank the Real Biker,
I did install both sets with dialectical grease. That's what was surprising about them being corroded. I knew I was in trouble when the parts guy said that the service department had to look at them. I just wanted them to look and justify that they did not work. They wanted to charge me to diagnose the problem, but they waived that with some persuasion. They then told me they could replace the pins at 1/2 hour each, for about $300. I don't think so.
I was pissed and called HD customer service, they also told me if they were corroded they aren't covered under warranty. (Only five months old)
I really like those lights but there are other options out there now. So HD won't get my money for them.
Quick Reply: Installed Electra Glo LED Saddlebag Lights
