91 stator out. How's it look?
Old 05-20-2017, 08:49 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
Default 91 stator out. How's it look?
Replaced the battery and cables to the battery. Battery tests good. Bike is not charging it. I'm assuming it has to be either the stator or regulator. I pulled the stator tonight. I did testing from the sticky before hand but wasn't quite sure on the results so I opened it up to have a look. Here what I ended up with.
Attached Thumbnails 91 stator out. How's it look?-img_0653.jpg   91 stator out. How's it look?-img_0652.jpg
Old 05-20-2017, 08:54 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,028 Likes on 651 Posts
Looks burned to me
Old 05-20-2017, 08:56 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,693 Likes on 1,341 Posts
What numbers did you get when you went through the stickey?
Anyway, if it's torn down this far, put the 32 amp kit in it and call it good.
RANGER73 (05-21-2017)
Old 05-20-2017, 08:58 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,694 Likes on 1,150 Posts
Seen worse still running
Since it's out connect an ohm meter to the 2 terminals,meter should show no connection. If no connection shown put one meter lead to a terminal and touch the other to the body of the stator replete with other terminal. Again should show no connection.
If any connection is shown in either test the stator is toast.
That's about all you can do since it's outta the bike best I know
WP
Old 05-20-2017, 09:30 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
Pretty simple to pull apart. I don't mind wrenching and have never had one a part so sound like a good project for this weekend. Already looking at 32 amp kits. Do you recommend one over another?
Also wile I'm at it should I go ahead and put in a new 30 amp breaker too?
Old 05-20-2017, 09:42 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
If you go aftermarket then get Cycle Electric.
The following 3 users liked this post by texashillcountry:
Campy Roadie (05-21-2017), tar_snake (05-22-2017), TwiZted Biker (05-20-2017)
Old 05-20-2017, 10:06 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
Not seeing a kit listed for a 1991 heritage classic?
Old 05-20-2017, 11:04 PM
Bingee's Avatar
Bingee
Bingee is offline
The Cycle Electric kit for your '91 Heritage is CE-32ALP. You get rotor, stator, and regulator. google for best price.
Old 05-21-2017, 05:37 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,792 Likes on 3,303 Posts
As Asked.. what were your test results?????
The Cycle Electric is all I use and "ALL I WILL EVER USE" Nobody make a better stator or rotor...... Period...... Listen to what everyone is saying.....
Old 05-21-2017, 05:42 AM
grbrown's Avatar
grbrown
grbrown is offline
Stator looks OK to me, but if burned out I understand they smell very strongly, which leaves no doubt that they are a gonner!
Quick Reply: 91 stator out. How's it look?
