evo motor
Old 05-24-2017, 04:56 PM
glavook's Avatar
glavook
glavook is offline
Stage I
Default evo motor
what kind of transmission oil goes in a 1988 heritage softail 1340cc?
Frank Maleno (05-26-2017)
Old 05-24-2017, 05:35 PM
FreedomRider's Avatar
FreedomRider
FreedomRider is offline
I used HD's Formula Plus in the tranny and primary.
Old 05-24-2017, 06:46 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
Tranny , I use Lucas gear oil
Old 05-24-2017, 07:36 PM
Tony_N's Avatar
Tony_N
Tony_N is offline
85W-140 Hypoid gear oil.
Old 05-24-2017, 08:09 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,681 Likes on 1,338 Posts
I use Mobil SHC-630.
Old 05-25-2017, 05:01 AM
br549A1's Avatar
br549A1
br549A1 is offline
Redline shockproof
Old 05-25-2017, 05:08 AM
grbrown's Avatar
grbrown
grbrown is offline
Exclamation
Welcome to HDF. You will come to realise that there are more brands of oil than any mere mortal can hope to use in a lifetime! Some are suitable for our bikes and others are debateable. Your choice for any oil in your bike is almost unlimited, so to see discussion on the subject visit the Tech Oil section - but get a long drink first! Or take the easy option and visit your local Harley dealer.
Old 05-25-2017, 07:18 AM
RLH3175's Avatar
RLH3175
RLH3175 is offline
Received 2,405 Likes on 901 Posts
Let me add my $.02 worth. I use Lucas Oil Transmission and Diff Gear Lube 75W90 synthetic, in the trans on my 1996 Harley. The brand doesn't matter, but to protect the gears you need gear oil/grease. As old and loose as the transmissions are on a bike as old as ours, 75W140 might be better. Gear oil needs to stick to the gears as they rotate and be thick enough to remain between the teeth on the mating gears so that they are not metal to metal but always have a protective film of grease between them.
Old 05-25-2017, 08:35 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,695 Likes on 1,985 Posts
Valvoline 85W-140 hypoid gear oil. $6.00/qt. at Auto Zone.
I used H-D semi-synthetic transmission lube until they discontinued it.
Old 05-25-2017, 10:38 AM
IRON1250's Avatar
IRON1250
IRON1250 is offline
Never had any issues using the oil HD recommends for each hole on my Harley's.
Quick Reply: evo motor
