Blowing a fuse with the cruise?
Went to the Dragon this weekend. While there I ran into a problem. Was driving down the road hit the cruise button on the handle bard by the throttle and the bike died. Pulled over found Ignition fuse was blown (15 amp). Put a new fuse in worked well. Later hit the cruise and the fuse was blown again. Well now I am home and want to find out what caused it? Has anybody else had this problem. All other switches on the right side function correctly. Thanks
Stock bars. I think I found the problem. I took apart the throttle side switch holder. Checked everything. I think the wiring was pulled too tight which caused a pinch. I trailered my bike a few weeks ago. At that time I put the power straps on the bottom of the handle bars. I always put the strap between the wires and bar not over as not to pinch it. When I did that I had to spread the wires from the bar first making it too tight at the end. I am guessing. Just took it for a ride and no issues. Thanks for the advise.
