I just noticed just before I took off the muffler to remove rear wheel I noticed the muffler is loose. At the time I didn't think nothing of it till it was time to put them back on. After I tightened everything on the right muffler is still loose so now not sure whats up with this. Any ideas why?
Joe I had the same problem on my Road King. No matter how tight I tightened the clamp bolt it would still shake loose. A new set of clamps fixed it. Go ahead and buy a pair and replace both sides, I think they were around 7 or 8 dollars from the local HD dealer for the pair.
I use RTV at the joint. Not to keep things tight, but to keep the joint from leaking. Never a problem taking muffler off when I need to. RTV is what the factory used, by the way, at least that's what was on mine when it was new.
Get new clamps and a smear of RTV inside the muffler.
Those clamps are defective. They aren't able to be screwed down to a small enough diameter to tighten down on the pipe. I took mine and chucked them up in a vise and wailed on them with a 4lb sledge hammer for a while so they could be tightened properly. They work much better now.
