Satans Dyna Fxrt Build
What's up. Everyone calls me satan, son of satan, lucifer, etc. Im a soon to be harley tech, graduating in a month. Sold my shovel and bought an fxdb and I'm lucky enough to be in a position where I can build one of my dream bikes. Now I'm from Ohio, and we don't have very many fxrt style bikes running around. In fact I've never seen one in person (in this state). Before you ask , I won't be doing wheelies or stunts. This bike is being built for aggressive riding through the valley and long tours with what ever chick I can pick up on the back haha.
this thread is mainly for my amusement and to archive everything I've done. Will be word heavy, i like to write. Now onto the build:
This is my 13 Streetbob. Mostly stock. Things like forwards, derby cover, and slip ons were already on the bike when I bought it. As it sits it has about 3666 miles on it.
first things first. Put her on the lift and started ripping her apart. The bike is getting a new paint job so everything has to go
Seat, fender and tank being ripped off. Removed battery box, and left side cover aswell. Nothing too crazy yet.
As you can see I removed the forwards, the outer, all the clutch and compensator guts and the inner aswell. Not a daunting task. But let's not kid ourselves. Switching from forwards to mids should not be this hard. And by the time you replace the inner main shaft seal, mid shaft bushing, gaskets, 5x inner sealing bolts..... this **** adds up. FAST.
however, it's "cheap" insurance
So far, the best part about this build is I get to do a full inspection on the bike. Getting an idea of how the PO took care of the bike and making sure everything is torqued properly is well worth the teardown in my opinion.
after I got the primary off , I took the tank off, the stock bars and a lot of chrome pieces that I ended up powdercoating black. I started with my pushrod covers, lifter covers and rocker boxes. Along with small details such as the pivot shaft cover and the neck stem cap
Prior to powdercoating obviously. The reason I'm powdercoating the lifter covers and rocker boxes is they were corroded and ugly like the one above. The pushrod covers were just ugly chrome.
Not the best picture. But the powdercoat came out perfect (ignore finger prints) and it looks 10x better than it did. I'm debating on powdercoating the rocker box covers the same high gloss black. Personally I like the contrast but some people are saying I should match them. What do you think ?
bought some awesome risers and bars and threw them on. Also started working on blacking out the front end.
Made my own upper fork sliders and found some cheap 49mm boots on Amazon. I also blacked out the levers and even the pivot pins which had chrome tops. I chose a good time to buy powdercoating equipment.
also I'll note I pulled the exhaust off and installed a high flow backing plate aswell. Getting a new exhaust and tuner. 555 cams later.
that's it for now. I have a lot more done but I'll post sometime this week. And have way more things to do once parts come in. Thanks for reading
