Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Parts list- S&S hot set up a/640 cams
S&S tc3 oil pump and plate kit
SE 58mm with 5.3 injectors
Oil cooler kit
Primo Rivera pro clutch
I'll be reusing my D&D bobcat.
Hotrod I'm building what I have. Dave as far as a backing plate and a.c. I don't THINK my current setup will work so I'll need to come up with something.
You might want to just go to a 117 if you can.... Lately it seems to be the hot setup.......
