I have a wobble. U can kinda feel it at low speeds but at 86 she wobbles. So took the front wheel off. My question the spacer between the wheel bearings is that suppose to be loose. I checked my 2012 wheel and it's tight in there. Thanks
When new wheel bearings are installed,the right side is the last one and it is pressed in against that spacer so that it just touches it.So you should feel a slight movement in spacer.
