Rockets C Fender chop, lighting, and 260 Metz
Well, since you asked... I think your fender looks like a work in progress...and would look a lot better if it had some shape to it, with the edge finished, instead of just chopped off square...Then repainted, with (or without) the flames that are now cut-off mid flame....Not sure about the lights?? They look bright, I'll give ya that....
Sorry , just my honest opinions.
skid_pimp (06-24-2017)
I think when I first looked at it my focus was more drawn to the tire and it's sheer size so the fender looked fine. After adjusting my focus solely to the fender itself, although I don't think it looks terrible or like a "hack job" like someone else mentioned, it does look like it's missing some shape to make it flow with the rest of the bike.
I've given a lot of thought to chopping my rear fender as well. Now that I see it as a square cut I'm not very fond of the look. I think you can alter the shape and still make the fender look decent. Maybe follow a similar curve like that on the end of the piece you cut off and give it to the current cut fender. Once you're happy with the shape and made the edges look nice you could just paint the fender all black and forget about the flames.
Another idea is to take the piece you cut off and weld it on top of the remaining fender and extend it a couple of inches and utilize the curve that is there. You'd have to fill the holes and bondo it all together and then paint it, but I think that would look good as well.
I'd like to see some detail on how you did the LED lights on the swing arm. I've been thinking of doing something similar to my Rocker. I bought some aluminum C channel that I will bend and attach to the swing arm and drop the LED's inside the channel.
I'd also like to see how you made the license plate frame and attached it, etc.
It's a good effort but I think it needs to be cleaned up a bit and given a flair of style.
