Primary chain lube
Primary chain lube
I have an 03 Road King Classic. What is the heaviest lube I can put in the primary. I'm running Lucas at the moment and prior to that formula. I notice that when hot both of those are like water. Can I put something heavier in that wont hurt the clutch? I know basically its a splash set up and really not for lubrication more so to just keep the chain wet. My chain is good, bearing fine, adjusted dead on but when hot its noisey. I know its the nature of the beast but when the bike is not a full operating temp, the primary is rather quiet till the lube thins out due to heat. Just looking for a weight number.
randy
randy
Oil in the primary is for cooling more then lubing.I think with a heavy lube in there your going to have problems,especially with the clutch.try using a lube specific for the primary,like spectrol,redline,belray and so on.I also run mobil 1 4t racing in the primary,works great.you may also have a worn or loose chain.If your swapping oil maybe you should pop that cover and take a peek in there.check your ajuster shoe for deep wear marks.Ajust chain to spec.
it's hotter here than it gets there...
I use the primary+.
here's the big thing- the clutch plates absorb lube.
if you start changing lubes it is possible that you have a lube in the primary which is not compatible with the lube absorbed in the clutch plates- and you get slipping
better for the clutch that whatever you use from the day you buy your plates and soak them in lube, ( whatever brand) that you use the same type
as for primary- I had great luck with the hayden m6 on both of my evos- a smart easy $75 job. mine was related to my worn out shoes ( at about 50k) and the result gave much smoother downshifts and low speed operation.
the 09 has harley's auto tensioner and so far so good
Mike
I use the primary+.
Mike
Received 4,283 Likes
