2017 tri glide excessive heat
Hello all im new here
i just purchased a new 2017 tri glide ultra. Went from a 2007 roadking classic .
I notice that there is a lot of heat coming off the right side of the motor. Is this normal .
Also im 6 ft and have a big fram is there a seat out there that will make so i sit back a little more so my nuts are not getting crushed on the gas tank
SpringerRider (09-21-2017)
You may look around for a dealer that has some demo seats that they will let you try. As for the heat we make a product called a Crotch Cooler that will really help you with the heat from the rear cylinder and while sitting in traffic . Good luck ..
Received 3,939 Likes
There are quite a few things you can do to get the heat down...both for you benefit and for the engine longevity. You can read a report on it HERE.
One of the first things you can do to get some relief for your right ankle and calf are the Floorboard Extensions that you can see HERE.
Not only will they get you away from the heat...they are quite a bit more comfortable in terms of giving you more room to move around.
I experienced the same heat issue on my right ankle, so I installed the DK Floorboard Extensions & they solved the problem for me. I don't even think about the heat anymore, and as you know, its been pretty hot here in FL lately.
Can't help you with the seat problem, as the OE seat works fine for me.
DK Custom (07-03-2017)
If I was home I would let you check out my tall boy seat. It got me back a little from the bars.
DK Custom (07-30-2017)
now just have to think about comfort lift kit and new shocks
