Clutch lever
Old 07-24-2017, 04:44 PM
Big Gonzo's Avatar
Big Gonzo
Big Gonzo is offline
4th Gear
Default Clutch lever
Just recently bought my wife a 2014 Triglide I was wondering if I can adjust the clutch lever to accommodate her small hands, or is there a lever out on the market that can help her? Any help will be appreciated.
Old 07-24-2017, 05:39 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
You have the hydraulic activated clutch so there isn't any clutch adjustment.
Several companies make reduced reach/adjustable levers. Do a search for "reduced reach clutch lever". Softbrake & Oberon @ Hogleverage are 2 possibilities.
Old 07-25-2017, 07:52 AM
JTimes's Avatar
JTimes
JTimes is offline
Check out HogLeverage. They sell adjustable levers that will work with the hydraulic clutch. I know some ladies on my Freewheeler FB page that have used them on their trikes. http://www.hogleverage.com/store/c23..._FLHTCUTG.html
Old 07-28-2017, 08:58 AM
Peddler95's Avatar
Peddler95
Peddler95 is offline
Stage I
Just put on the Oberon clutch lever this week.
Only have about 100 miles using it but, overall, am well pleased with it.
Solved the biggest problem I had with starting hard left corner turns (turning around especially) where the left grip is close to my body, limiting my ability to feather the clutch.
My only complaint is, I would like to use the number one position, it works perfectly with the exception it takes away the ability to start the engine in gear. I guess it does not allow the lever to move far enough to close the clutch switch but does completely disengage the clutch.
This makes it pretty far from an adjustable lever. If 3 is about the same as the stock lever (as stated by the seller) and 1 has the problem I stated, that leaves only one selection (2).
Old 07-28-2017, 10:57 AM
rhino 2's Avatar
rhino 2
rhino 2 is offline
I have the Oberon, Like you say with #1 the trike will only start in neural...'
For me #2 is just right, So its set it and forget it...The other problem is the lever is too short, And crimps my hand a little. I'll live with it because the stock lever's engagement point was way too abrupt for me...But just like everything else in life there are compromises to be made......
Old 08-02-2017, 08:28 AM
HDDOC's Avatar
HDDOC
HDDOC is offline
I have found the same as you, But can live with it. One other thing is I have the magnum grips and can on start in neutral and keep #2 postion
deacon1984
06-10-2022 07:51 AM
Sanjuro
04-27-2020 06:42 PM
paid4c4
2014-2023 Touring Models
04-13-2018 10:23 AM
Erilflynn
04-04-2017 07:14 AM
Bankrupt
Exhaust System Topics
04-11-2011 05:36 PM
Quick Reply: Clutch lever
