How do you break YOUR Dyna in?
The Break in modern manuals is simply the manufacturer covering their butts. One thing on new stuff that can happen is a complete failure in a part or a missed bolt coming loose..ect
They want you taking it easy so you can get it stopped in time or at least minimize the damage you do to others. It's going to so called break in no matter how you run it...Modern production is so close now, it's probably broke in in the first mile.
People who ride it hard to break in report no problems.
People who pamper it for first 1500 miles report no problems.
Unless there is a study on two bikes that are exactly the same and maintained the same by the same rider who broke them in differently and monitored them for the next 50,000 miles and looked for problems, there is no hard evidence that the break in makes any difference.
And even then, those results have to be repeatable by other riders who bought two bike exactly the same and maintained it the same and....
MotoTune all the way...did the FXDLS on ride home.
I agree.
Change the fluids and oil filter every 10K or so and it will easily go 100K when driven like one has some sense. (who knows what that means these days....) Bang the rev limiter between every red light and you will be back to your 50K if you are lucky.
Mine at 50 K still runs like new and has compression like it did back at 10K when I changed the first plugs. I change the oils ever few years. Tires and brake pads. And Harley's 10 cent brake light switches. My buddy did tear out the alternator rotor spline but that was his fault locking the engine up when he blew the rear tire.
Received 5,388 Likes
Do the proper initial heat cycling..., easy (somewhat.., but no babying) over the first 500 to 1K mi
Let R rip after that
Other times - heat cycle - then dyno break in
It mechanical..., and a machine - once all the pieces & parts seated / grooved in / mated up - it either going to work..., or blow
Ghost
Ghost
