Are u checking tire pressures?
Old 09-17-2017, 11:10 PM
Salmo pass's Avatar
Salmo pass
Salmo pass is offline
Default Are u checking tire pressures?
So over the last 6 months I have checked tire pressures regularly, more so than I have over the last 30 years. I have probably checked air pressure 15-20x. Today I have 10600 miles(18000km year to date. I have not had to add any air to the front, and the rear I have had to add air because I believe of the air I lose trying to check it. It is a royal pain I agree. I ride in a wide range of temps, today I started at 2c which is probably 37f and I ended at 16c, 60 ish F.
Is this what you see as well? This is consistent with what I have seen with my other bikes saw well, both tubed and tubeless. Current ride is ultra classic 2009 tubeless rims.
Old 09-17-2017, 11:21 PM
NORTY FLATZ's Avatar
NORTY FLATZ
NORTY FLATZ is offline
Received 5,388 Likes on 2,952 Posts
Your (and our) ambient air temps are going to start to come down. This makes the pressure come down too. Keep checking both tires before every ride.
What tire pressure do you use?
Old 09-17-2017, 11:34 PM
Salmo pass's Avatar
Salmo pass
38f 40 r. Happy with mileage and wear patterns. Currently riding AE and mileage is comparable to OE. Currently have 23kkm about 14000miles on rear.
Old 09-18-2017, 12:23 AM
Thingfish's Avatar
Thingfish
Thingfish is offline
I check tires regularly and almost always need around 2 - 4 lbs.
Old 09-18-2017, 05:53 AM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
check em two three times per week in riding season. i ride everyday.
40/40, no issues, typical 12 to 15K rear 22k to 25k front.
usually 2 rears to 1 front which means rears are not completely worn out when changed.
im more rear brake than front, dont like to push rears to wear bars. tar and chip roads make for interesting ride in semi wet condition when rears are worn.
using stock dunlops, switching to Pirelli this change. heard good things about the night dragon GT.
Old 09-18-2017, 05:57 AM
farmboy555's Avatar
farmboy555
farmboy555 is offline
I try to keep the pressure checked and also keep ride on in the tires
That's the only way too get the mileage on the tires is to maintain them
Old 09-18-2017, 06:41 AM
Strugatsio's Avatar
Strugatsio
Strugatsio is offline
I check air pressure every time I ride. What's the mystery?
The OP makes it sound like a colonoscopy. It's no big deal.
Old 09-18-2017, 07:48 AM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,070 Likes on 2,554 Posts
I check mine but apparently not as often as others who've posted. The shop puts nitrogen in the tires and they said not to put air in them because it effects the nitrogen in them.
Old 09-18-2017, 08:25 AM
cowboydoc's Avatar
cowboydoc
cowboydoc is offline
Received 1,076 Likes on 450 Posts
I check pressure before almost every ride, just part of the routine maintenance. If I am leaving early in the morning I will check them the night before. I rarely need to add more than 1 or 2 psi. I run 38 front and 42 rear. I got 17k miles from the stock rear tire, and changed both tires (Michelin Commander 2) because it would have bothered me to have an old tire and new tire of different brands together.
I was also taught to check the oil every time I filled up with gas, and it is a habit I still have today. I am amazed at how many people don't even know how to check the oil level. A coworker recently asked me about a funny clicking noise coming from her car. It was 3 quarts low. Her comment - but the oil light never came on.
Old 09-18-2017, 08:33 AM
upflying's Avatar
upflying
upflying is online now
Received 26,178 Likes on 11,108 Posts
Air is 78% nitrogen, mixing air with nitrogen is harmless. I suspect the shop wants you to return to spend more money on genuine nitrogen.
The following 3 users liked this post by upflying:
HKMark23 (09-20-2017), Hurricane 68 (09-18-2017), shorelasHD (09-19-2017)
Quick Reply: Are u checking tire pressures?
