98 Heritage suspension issues
Hi all....first off I'm sure some of this info is already in threads but I don't have a month or 2 to search them all so....looking for ideas and advice. I am a 20+ yr veteran of riding but am on my first Harley. My 98 Heritage Classic has been modded a little and lowered. I like the look but I'm too heavy (I think, 6' 250#) for the lowered suspension. First, the rear shocks are shot to begin with and I am looking where to turn.
I live in NC, I am an aggressive rider due to my old days on crotch rockets and ride mountain territory almost always therefore I have lean angle and grinding issues. I grind the lower pipe, floor boards, bottom out frame on humps and dips in the road....sometimes when entering a bridge, those small humps between the asphalt and concrete just slam my frame.....I am tired of all this and looking for advice on suspension changes. I understand my bike isn't quite made for my riding style but I like it and plan on keeping it and can't afford a 2nd bike. My lower pipe is about 1/3 closed from dragging and I have actually picked the rear wheel up off the road from leaning in too hard.....yes, makes you pucker a little.
I am curious about different shock attributes and what all everyone has done in similar circumstances. Factory shocks raised to max height? Progressive shocks to "hold" the ride height better? Air shocks? What y'all got?
Shocks are a popular subject all around HDF, but I confess not noticing many options for softails. It may be worth visiting the Softail section to take a look, all quiet like, to see what they know over there.
Forks are easier and there are options from simply replacing the stock springs with say Race Tech single-rate, matched to your weight. Installing them and setting sag correct may lift the front a little and should improve ride quality. There are several brands of cartridge inserts available, to give further improved ride comfort.
Received 4,317 Likes
I like my 422 Progressive shocks and springs but Prot has made a good case for Ohlin shocks.
As for springs the only ones I've used so far is the Progressive.
Here are the springs I use
http://www.progressivesuspension.com...ork-spring-kit
Received 14,163 Likes
It's Works Performance that I advocate for Softail shocks. They can be rebuilt either by works or by purchasing a rebuild kit.
I went through two or three sets of progressive 422's and needed to do something else and didn't want the complexity of air suspension.
I set mine to slightly taller than stock height and the floorboard grinding stopped. Handling also improved around curves.
For some reason my tiny mind was thinking you said Ohlins but once again (as usual) it was wrong.
I have a set of stock HD softail shocks with the height adjustable mod...they only have 20K on them...you can have them for $40 shipped.
Stock hd shocks are adjustable for preload for the rider's weight. it's a pain to adjust but it might help.
I might try progressive or air ride....the $1500 cost of air ride means it will have to be in a year or two. I don't know if it's worth dropping 4-6 hundred on progressive shocks an the improvement not be that noticeable an just wait until I can afford air ride. I'd like to ride a softail with the progressive an air ride to compare.
