Wheel bearing question. Who makes the best.
Old 10-15-2017, 04:30 PM
Rollcage's Avatar
Rollcage
Rollcage is offline
Default Wheel bearing question. Who makes the best.
I have to do new sneakers on my Fat Bob.
I figure if the tires are coming off, I should do the wheel bearings at the same time.
I have used the search function, and I have also read something about Fxdf bearings failing sooner than other Dyna's.
I have read that all ballz are good, but wondering which ones I should order to drop at the Indy with the bike.
Off topic, but I'm also looking for a link and info on sprocket change while I have it apart.
Old 10-15-2017, 05:02 PM
Kraken's Avatar
Kraken
Kraken is offline
Timken. 205PP if you have 25mm and non-ABS. All Ballz are foreign made just like the Harley ones.
Old 10-15-2017, 05:49 PM
Rollcage's Avatar
Rollcage
Rollcage is offline
Please forgive me, I am just trying to learn.
How would I know if I have 25mm, and I will Google, and it is a NON abs bike.
And am I correct in assuming that the fronts and rears will be the same bearing, and I will Beed 2 per axle.
2014 fat bob
Old 10-15-2017, 05:55 PM
Screamin beagle's Avatar
Screamin beagle
Screamin beagle is offline
Received 3,991 Likes on 1,997 Posts
Why not have your indy order them? You'll get the right ones and he'll probably warranty the work since you brought them from him. Disclaimer: I am not in anyway affiliated with your indy lol. Sorry I don't have any good technical information for you
Spartagus981 (02-04-2020)
Old 10-15-2017, 06:05 PM
Rollcage's Avatar
Rollcage
Rollcage is offline
To be honest, my Indy is BURIED with work.
I like to do the research myself, it helps me learn, and I've seen everyone make mistakes.
My local HD dealer is a juggernaut when it comes to making mistakes, this is why I use a local Indy.
I drop the bike off with all parts needed for jobs I can't do home, and he just gives me an hourly labor rate.
I enjoy the legwork
Old 10-15-2017, 06:44 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
Old 10-15-2017, 07:37 PM
Kraken's Avatar
Kraken
Kraken is offline
2014 fat bob
Yeah, 2 per axle and front should be the same as the back. Timken 205PP.
Old 10-15-2017, 07:42 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 47,719 Likes on 18,538 Posts
Always use a thread lubricant on the threads of the tool !!
Old 10-15-2017, 08:08 PM
MRFREEZE57's Avatar
MRFREEZE57
MRFREEZE57 is offline
Received 4,036 Likes on 1,893 Posts
if you have a 2014 model, timken 205PP will work and are made in USA, check on E BAY, picked up a set for 18 bucks ea, the dealer wanted 29ea, I also ordered an extra set as I lost one in the rear last July 150mi from home. check them good every tire change. these seem like very small bearings for a bike that heavy.
Old 10-16-2017, 07:23 AM
Dynaglide92's Avatar
Dynaglide92
Dynaglide92 is offline
Best bearings are world wide bearings
ceramic coated cost around 200 a set
i use timken 205 pp you can find them for 30 a set
Quick Reply: Wheel bearing question. Who makes the best.
