You won’t believe this!
I was riding around the coast this evening with a passenger, and suddenly we heard a scrape sound on each revolution of the rear wheel. Didn’t think much of it. I get home, and investigate. Sure enough, the bike vibrates loose every Allen bolt holding the rear sprocket in place! I hand tightened them but I need to really secure them. What do you recommend?
not sure, couldn’t tell ya. The chrome belt adjuster cover is stamped KOREA inside so maybe aftermarket? I was hoping just to be able to loctite these bolts back.
Whoever works on that bike should loctite every fastener. I suspect you need stronger than blue on those. Maybe yellow?
http://www.type2.com/library/chemicals/loctite.htm
Stud Duck (10-18-2017)
Received 14,657 Likes
Link
Seek and you shall find!
http://loctite.sg/sea/content_data/L...tion_Guide.pdf
Received 2,189 Likes
You got lucky....
https://www.hdforums.com/forum/dyna-...-new-post.html
get new bolts (those are cooked now) and loctite them
