Do it yourself cam installation M8
Old 10-23-2017, 09:48 AM
Oldskewl's Avatar
Oldskewl
Oldskewl is offline
Received 7,906 Likes on 3,285 Posts
Default Do it yourself cam installation M8
I've done numerous shovel heads but never opened up anything later.
Watched cam installs on EVO's but never done one myself. Tools are not an issue,.. Anyone here done a cam install on an M8 themselves?
Old 10-23-2017, 10:25 AM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,395 Likes on 1,561 Posts
About 40 - 50 of them, what's your question?
Old 10-23-2017, 01:22 PM
Oldskewl's Avatar
Oldskewl
Oldskewl is offline
Do I need a specific cam bearing removal tool for this motor or do I need to fabricate one? That's where I'm most concerned.
Old 10-23-2017, 03:12 PM
SavageChopper's Avatar
SavageChopper
SavageChopper is offline
Every cam install that I have done, I've printed a copy of the installation instruction from S&S to use as a guide. I was just looking at a guide on the M8 cam install the other day.
While you can use a blind bearing puller available from rent most auto stores, I recommend the proper install tool for pressing in the new bearing. The tool sets the bearing to the proper depth and is a little nicer than beating it in with an old cam and hammer. George's garage should have a tool available next month. Just my two cents on that.
Oldskewl (10-23-2017)
Old 10-23-2017, 03:34 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is online now
Platinum Sponsor
Received 4,104 Likes on 1,339 Posts
We did a basic overview of the M8 cam install in the following thread https://www.hdforums.com/forum/milwa...ep-w-dyno.html
As far as the inner cam bearing replacement you can use most brands of the Twin Cam tools to remove the bearing from the cases which is simple, however when putting the new bearing in the case you need to make sure you set it to the proper depth. Some TC kits use a driver which allows you to carefully set this. Jims USA is now offering their retrofit kits to upgrade their TC kit for use with M8 engines and as another user noted above George's Garage will have their kit available soon as well.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old 10-23-2017, 04:17 PM
Oldskewl's Avatar
Oldskewl
Oldskewl is offline
Thank you everyone. I think I'll order the Jims set so I have it in the tool box, I'm sure this is a piece of cake but I'm nervous at the same time
Old 10-23-2017, 07:35 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
It is no big deal, just take your time. It is best to cut the old pushrods out as this will save you tons of time that more than covers the cost of the pushrods. The cam bearing tool I use is the SE one from the TC and it works perfect. Putting the new one in is not different than a TC as well, just set it flush with the case, NO magic to it at all. The only thing to be careful on is the alignment of the Cam plate and the oil pump when going back together,
Old 10-24-2017, 12:56 AM
badcooky's Avatar
badcooky
badcooky is offline
Puttnutt over in Softails has a cam swap with pictures in his thread.
https://www.hdforums.com/forum/softa...fat-boy-s.html
Oldskewl (10-24-2017)
Old 10-24-2017, 12:24 PM
Oldskewl's Avatar
Oldskewl
Oldskewl is offline
Thanks for the link.
Old 10-24-2017, 07:22 PM
badcooky's Avatar
badcooky
badcooky is offline
Thank the Nutt brother it's his thing.
Cheers.
Quick Reply: Do it yourself cam installation M8
