100K Makeover (Belt or Chain)
So I posted recently about my 100,000. mile makeover on my 07 RG, I'm installing S&S T-111-Baker 7 speed-Heavy duty clutch-Baker compensator sprocket-Stater-Heavy duty starter and a Thunder max tuner. Last question "Drive belt or chain"?I need to replace the front and rear final drive sprocket along with the belt, Mind you I have 100k on this bike and the OEM belt is surprisingly in decent shape, but I would never consider leaving it at this point. My boys are telling me go chain, it will hold up better with the added HP and Torque, I'm not sold considering they need to be replaced around 20k (so I'm told). I'm still leaning toward the drag specialties heavy duty belt. Anyone have personal experience with final drive chain?
That point made there is enough to convince me to stay belt drive. It really seems like you like to ride your bike. True meaning of tour bike with those kind of miles. The really only reason IMO to go chain is for race applications.
Been doing shovelheads for 40 plus years both as my daily and working on them on the side, had my share of chain issues then some.
You had good luck with your belt on stock motor...now you're building your motor...
I went chain after my build...it's a little messy...but I'm not afraid of twisting the wick either...
Sometimes you should listen to your buds...
Do any of your buds run a comp delete/direct drive...?
smat
smat
Go back with the FACTORY HARLEY Belt & Pulleys, not aftermarket,,,
IIRC the '07 SG had the "tall gearing" since you are replacing everything you might look into later model ("shorter" final drive) gearing??
No issues on the '09 117/DD7 for 61k (40k on Build) so far...
I know guys putting 170+ to the tire, no issues running stock Harley Belts, my favorite Indy has done at least a half a dozen 143s all on stock Belts, no issues...
124HC / DD7, 115k miles on original Belt...
No way I'd go chain on a Harley street Bike...
