Fatbob 114 autotune
Fatbob 114 autotune
Hello, I’m new to this forum and new to auto tuning with the FP3. So V/H says they do not yet have any maps for my FATBOB. I just installed TBR exhaust to my 114 fatbob. I loaded the FP3 and started auto tuning from my stock map. Do I do 3 full 45 minute rides before finalizing the tune? Any advice would be appreaciated.
Thanks
If you apply learned values it will clear the map, so make sure to take a screen shot before you do. When I did it on my ultra limited, i applied a couple of times before I closed out the auto tune. Although I didn't have a very good experience with it. I like the fp3 but wasn't a fan of the auto tune. I almost dropped my bike a couple times because of it. For some reason when I would lightly give gas as I was letting out on the clutch the bike would start having blow back through the Intake and would stall out. Well, when the handle bars are turned and it jolts and dies,you realize how heavy 800 lbs really is. I ended up giving up on the auto tune and flashed the ecu with the remaining learned values.
imovelives (11-18-2017)
Can't speak for the FP3, but on the PowerVision, you select the map you want to autotune, then do a tuning run for as short or as long as you like.
Then you save those changes as a new map and flash that new map to the bike.
Then for the next run, you select that map, do the autotune process again and save it as another new map - flash to the bike. Rinse, repeat.....until you are happy.
Time or number of tanks of fuel is irrelevant ...you need as many green cells as possible. To get anywhere close, you need a lot more than is in the picture you provided.
V&H were going to do a how to guide ...guess it 'aint turned up yet.
If you are serious about tuning read the tuning forum and see what others do with other devices. Tuning is NOT as DIY as V&H FP3 would have you think, so good luck with the FP3
