Another Wheel bearing thread
09 ultra- no histroy on replacement but when i had the bike on the lift i jacked up the tire and it spun nice and free no problems . But i decided the best way to clean these rims was to take them off . When i had them off i ran my fingers around the bearings and was not right so i pulled them today
The orange one was abs and it was fine the other side had very little grease in it and it was burnt and black inside ,most of the cheap wire cage was gone and the ball bearings were rubbing against each other (the roughness i felt) this would have failed for sure in the next year and im glad i pulled them
For me this will be part of yearly inspection
Like i said i have no history but my second year of ownership
Im putting All ***** bearings front and rear so i have a starting piont if there are future problems
Dave
Dave
Received 4,614 Likes
I see a lot of bearings with that vaseline looking stuff in the bearing on the right, especially photos of ones that failed. When I run across that stuff in new bearings, I clean it out and put in a good quality name brand synthetic - and more of it than that bearing has. I lightened the photo so folks can see what I'm talking about.
I've used AllBalls in 3 motorcycles now, so far with no problems. They're double sealed on each side, have heavy ball cages, and are well packed with Chevron green synthetic. Might be Chinese made, but they're way better than Harley's Chinese made bearings, and have them in abs sizes, too.
This confirms my choice to spend $99 on a new Bearing Puller/Installer last week. 2003 FLHRCI with 55K on the odometer and OEM Bearings in it. Decided it was time to change the bearings, even though they pass the "Spin Test", but just because I figure that they are due. "All *****" has been my choice in the past, so I'll probably go that route again.
Dave
Dave
Mark
I have 33,000+ miles on my '13 CVO Ultra.
Hoping that I can make it to 40,000 miles or until the end of next season and I'll have new tires installed and have all of the bearings checked (and replaced)if needed.
I'd rather have the bearings installed while the bike is down for either new tires (or stored for the winter) than having a breakdown on a trip.
That sounds like a lot, I wonder if they are already a replacement set. The current ABS bearing is on its first revision, the plain bearing on it's second (third version).
