2018 CB install on Ultra Limited
Old 12-09-2017, 04:28 PM
blkjac's Avatar
blkjac
blkjac is offline
Default 2018 CB install on Ultra Limited
I am going to install a CB on my '18 Limited. Can anyone tell me how to remove the currend switchpak without damage and install a new one with the ptt switch?
Old 12-11-2017, 12:41 AM
White Ice's Avatar
White Ice
White Ice is offline
Step #1 - purchase service manual.
Step #2 - follow step by step procedure for switchpak removal/replace.
Step #3 - store service manual in a convenient location for future reference.
It will be the best $48 you've ever spent.
Old 12-11-2017, 06:39 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,343 Likes on 3,278 Posts
Service manual is your best friend if you’re gonna do work yourself, spend the money ...
Old 12-11-2017, 07:26 AM
Babyboy's Avatar
Babyboy
Babyboy is offline
The Limited came stock with the CB radio. The Ultra does not come stock with the CB.
There are a few differences between the 2 models unless the MOCO is getting cheaper and only offering the CB as an add on option for the limited in the new bikes.
Old 12-11-2017, 07:45 AM
yooperhog's Avatar
yooperhog
yooperhog is offline
i absolutely agree, and with holidays comin up, watch for 15-20% off. knocks em down $10
Old 12-11-2017, 02:39 PM
MMXIWG's Avatar
MMXIWG
MMXIWG is offline
Starting in 17, the Limiteds no longer come with CB. Only CVOs come with CB now.
Old 12-11-2017, 05:24 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
I need to spend a little more time at the stealership is see instead of in my garage
Old 12-12-2017, 02:03 PM
1pkraft's Avatar
1pkraft
1pkraft is offline
I second or third buying a service manual - by the way the price for one has shot up to over $100 now - you don't really need one for the switches.
Remove the screws holding the switch cover and you'll see the actual switch is a plug and play module. Carefully remove the stock switch and replace with the new one that has the CB push to talk button.
Might want to consider replacing the switches on both handlebars with the lighted ones. Dealer quoted me $166.95 for the right hand switch with CB button (part # 71500130B) and I was ready to pull the trigger until I looked at the lighted switches. Price was $249.95 (part # 71500248B) and now switches on both handlebars have a nice LED light.
Old 12-12-2017, 05:25 PM
Notgrownup's Avatar
Notgrownup
This is true, buddy of mine just did his with lit switches...
Old 07-06-2018, 07:35 AM
scodav's Avatar
scodav
scodav is offline
On the 2018's, there is a black plug like part that is inside the hole where the mounting stud goes. To install a B2B on the 2018 Ultra, how does that black plug get removed? Also, is the antenna wiring already in place. Meaning just install the B2B unit in the fairing, I assume there will be a TNC connector for the antenna, then, install the stud and antenna to the tour pak? Does anyone have pictures of the removal of the plug?
Jshipley90
08-23-2015 08:20 PM
milkbone
11-15-2014 07:11 PM
SteveXL
05-08-2008 08:01 PM
jeffbarb17
01-18-2008 05:53 PM
KillerBee
10-08-2006 06:09 PM
Quick Reply: 2018 CB install on Ultra Limited
