Clutch cable leak....
Old 01-16-2018, 03:17 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,810 Likes on 3,315 Posts
Default Clutch cable leak....
Hey, I have a 2 year old Barnett clutch cable on my 98 Fatboy. After installing, I guess I didn't have it secured properly and the clear plastic coating on the outside was burned by the exhaust. I might get a drip or 2 in a day. Not a big leak but I know it's there and was wondering if anyone knew of a way to seal it up? A new one is over a hundred and I'd rather not if I didn't have to... Thanx...
Old 01-16-2018, 03:46 PM
dawg's Avatar
dawg
dawg is offline
Received 2,964 Likes on 1,715 Posts
Clear shrink tubing might help.
Old 01-16-2018, 03:49 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
With some seal all.
Old 01-16-2018, 03:51 PM
98hotrodfatboy
Originally Posted by Mark@ Baker Drivetrain
With some seal all.
Do do you have a brand name? Thanx Mark...
Old 01-16-2018, 03:54 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,541 Likes on 3,793 Posts
Black RTV. But just were is the fluid coming from. I have seen cables appear to leak from oil that gets away from you when you do a filter and getting into that outer protective tube that is over the actual sheeth that protects the spiral wrap metal sheeth over the the actual clutch cable which rides in another Teflon or some form of actual bearing surface for the cable.
Old 01-17-2018, 05:54 AM
BezerkoBob's Avatar
BezerkoBob
BezerkoBob is offline
Had a similiar issue on my 2013 FLHTK about 8 months after inistalled 13" apes and cables. Fixed mine with black shink tube that has a sealer inside. Most good electrical supply stores have it. Even some Farm & Home type stores do too.
98hotrodfatboy (01-17-2018)
Old 01-17-2018, 08:45 AM
98hotrodfatboy
Yea, I'm leaning that way. When I do it I'll heat the cable casing first then slip the shrink tube over it and torch it down.... I'm sure Napa has the good stuff....
Old 01-17-2018, 09:03 AM
98hotrodfatboy
With some seal all.
Took a couple of days but now I understand what you meant... Shrink tube with Seal-Tite.......
Old 01-17-2018, 10:02 AM
Seal-All:
http://hardwareonlinestore.com/index...hg7f5djqitnahs
Had a gas tank leaking on an old S-15. I put this on while it was leaking, kinda of bubbled up but it stopped the leak. Drove it for a couple years like that before I sold it. Hell it might still be on there.
Old 01-21-2018, 10:21 AM
98hotrodfatboy
I found Marine Grade Clear Heavy Walled Adhesive lined 3/4" Electrical Shrink Tube online.... Shrinkage is 3:1. The adhesive should seal it well. Ordered it this morning... I'll let you all know how it works....
utlonghorns416
02-10-2011 06:18 PM
crewzerdude
04-27-2010 09:18 AM
bg5377
14
11-11-2007 09:05 AM
bg5377
07-30-2007 01:45 AM
Sally88
09-22-2006 11:14 PM
Quick Reply: Clutch cable leak....
