Need help
Temporarily remove the tuner. You need to find out if the tuner is the problem or a factory component. Soot is from poor combustion, too rich, whether caused by too much fuel or poor ignition. Removing the tuner will easily check whether you have a spark plug wire starting to break down, a weepy fuel injector, a failing spark plug (swapping plugs would help check that also). You can check every component separately if you want, but if everything gets better without the tuner, then all of those components are performing properly. Any codes? The true duals makes the trouble shooting a little easier from one standpoint, you know the cylinder feeding the right side is suspect and can start there. Popping and roughness can also be caused by lean conditions, so that throws some complication into game. The rich cylinder likely does NOT have an intake leak, while the leaner side might.
How many miles? Do you use top tier fuel? Ever run any fuel system cleaner through it? Is it driven frequently or is it more of a low mileage garage queen that might be getting gummed up from lack of use? Have you done anything to the engine besides adding the tuner?
It has 50k miles and yes I use 91 octane always. Haven’t tried fuel additive, but it gets ride frequently, about 10k miles in the last 12 months, and only engine mods are intake and true dual headers. I did remove the tune and put it back to stock, I didn’t ride it yet to see if the soot problem stops but the weird popping sound is still there which really concerns me.
Top tier fuel has nothing to do with octane rating. There is top tier E10 regular, mid grade and high octane. In some places you can get top tier 100% gasoline in all three grades. Top tier refers to those brands that include a good detergent package that helps keep injectors, intake valves and spark plugs clean WITHOUT additional additives. Go to toptiergas.com for the full information and list of brands. I asked because you may well need injector cleaner at this point if not using the high detergent gasoline. Many like Seafoam, Techron, and I like Berryman's Chemtool. Especially with Berryman's, mix in the proper concentration for the size of your gas tank. It contains toluene and some other nasty cleaners and can cause damage if used in too high concentration.
