Loctite
I am not sure that I would use any type of Loc-Tite on my discs. But if I had to use some, it would definitely be the blue. You might want to remove the discs some day. The red is more for permanent applications and usually takes heat to remove the bolt.
Received 2,858 Likes
Usually, brake rotors and the drive pulley are red permanent grade loctite. What came on them from the factory was a paint on dry permanent grade on the bolts. I bet if you look in the service manual, it says to replace bolts. Probably because they will have it on them as the dry spray on. (not necessarily that there is something wrong with them as long as you replace with the proper grade)
Usually, when I have removed them, the bolt head be it torix or hex on the drive pulley, it's pretty roughed up and will show rust shortly.
Received 6,044 Likes
