Does the size of speaker wire matter? I’m only running speakers in the fairing using the stock wires. Being a short run from the amp to the speakers, would it be worth the time to repin the connectors and use bigger wire?
Whatever heavy gauge wire you decide to run the trace on the speaker output of the amp's circuit board will have much less current carrying capacity than the speaker wire connected to it. Any speaker wire around 18 gauge will more than suffice for your application.
The mm652 came with speaker wire that’s bigger than the stock wire. I wasn’t sure if repinning the connector and running the Polk audio speaker wire was worth the time
