Running 2 4ch amps ?
I have a DD audio d90 that i planned on bridging to a set of vo-m6x9, for the fronts i have a set of db drive wdx6motos that im going to try out if i dont like them i will most likely swap them out for a set of mmats. Planning on pushing those off another bridged 4ch, that amp i have not purchased yet.
Originally Posted by Houston_t
Ill go with the fade then. I see that 2 line levelers from biketronics will run me $160 and i can get a refurbished fix 86 for $200 whats the best course of action ?
If u have the fairing pod eliminators u can get 2 specific amps under the hood and 2 LLs without a problem.
If your amp has 2 channel input capability u will only need an RCA for each amp. Now if ur gonna want to run stereo, the amp may require 4 channel input thus u will need 2 18" Y RCAs for each LL.
T
I have a Road Glide so no pod eliminators (unless that's something new) almost considering getting rid of the factory head unit and going aftermarket, the ONLY thing i like about the factory unit is the fact that navigation shows dirt roads, other than that i guess i could really care less about the boom system.
If you have a dedicated amp for front and bags, what's the big need to be able to fade them? Wouldn't you just set the gains appropriately if the front or back was overpowering?
There are many trusted guys here, but I'd start with one LL and 2 simple Y adapter's assuming you can fit all that in the Road Glide nose. That's what I did and it's working great for me (Fairing though). I have a JL 280/4 and a Cerwin B52 on one LL in the fairing. You can always add another LL if you really need to later.
