Bending metal fuel line. HELP!
Old 02-23-2018, 11:15 PM
YammyBase's Avatar
YammyBase
YammyBase is offline
Default Bending metal fuel line. HELP!
Hi chaps
I need to bend the metal pipe slightly more into U shape to make the connection work without tanking in to the stealer. What would be the correct method?
Old 02-23-2018, 11:20 PM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is offline
Received 1,411 Likes on 452 Posts
Use a tubing bender. That's a sharp bend though. If your first attempt kinks it, fill it with sand before trying again.
mctraveler (02-24-2018)
Old 02-24-2018, 06:03 AM
Killa's Avatar
Killa
Killa is offline
I'm not sure about the "correct way",,,But I would put a slightly smaller socket in the radius then sqeeze the two ends together with channel locks or a vise using a rag or soft wood to protect the fittings. Remove o-ring first. Fittings might be too close to radius for a tubing bender. Just my 2cent
Old 02-24-2018, 10:36 AM
wwiiavfan's Avatar
wwiiavfan
wwiiavfan is offline
Received 1,082 Likes on 487 Posts
I would try to find a pulley that fits the inside radius, then clamp the tube into the pulley and say a prayer or two and go for it.
Old 02-24-2018, 11:59 AM
Killa's Avatar
Killa
Killa is offline
I like the pulley idea, maybe a plastic one since it would need to be cut out afterwards, but should make a nice bend.
Old 02-24-2018, 12:06 PM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,743 Likes on 980 Posts
Originally Posted by Killa
I'm not sure about the "correct way",,,But I would put a slightly smaller socket in the radius then squeeze the two ends together with channel locks or a vise using a rag or soft wood to protect the fittings. Remove o-ring first. Fittings might be too close to radius for a tubing bender. Just my 2cent
This is what I would do. Nail, bolt of weld the socket to a flat suffice, then put the fuel line down around the socket, then put a nail or bolt right behind the center of the fuel line to keep it from backing off the socket while you are bending the line. I would use a C-clamp so that you don't wind up bending too fast and kinking the line. This comes from my years of metal fabrication in a welding shop. The main thing to remember is Do Not Get In a Hurry.
Old 02-24-2018, 12:10 PM
Noisy Cricket's Avatar
Noisy Cricket
Noisy Cricket is offline
That's stainless steel. You can't. It will crimp as soon as you try.
Old 02-24-2018, 12:33 PM
Killa's Avatar
Killa
Killa is offline
Soooo how did it got bent into the shape it is in now?
(get bent)
Still like the pulley idea
Old 02-24-2018, 12:40 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,270 Likes on 11,143 Posts
As well, that’s the sample he is showing...not the one he’s going to bend.
Edit: oh never mind...I re- read the ops post. He does want to bend the one in his hand more. That’s gonna be really tight...
Old 02-24-2018, 12:41 PM
Noisy Cricket
It was bent prior to being cut. Not hard to do with the proper tools, very difficult without them. It can be done, but done properly requires a jig and heat and experience.
Quick Reply: Bending metal fuel line. HELP!
