S&s 106 kit
Old 04-20-2018, 10:29 AM
harley#1's Avatar
harley#1
harley#1 is offline
Default S&s 106 kit
Hey guys. Im looking at an S&S 106 kit part no.106-3760 for my 09 classic. heard something about bad pistons with certain kits. is this kit ok to have, thanks.
Old 04-20-2018, 10:45 AM
memphisharley's Avatar
memphisharley
memphisharley is offline
while I can't answer you question as I am looking to do a 107 or 110 kit. when I do I am going to contact hillside, veetwin or FM as I believe they sell their kits already checked and ready to install. s&s may do as well but I can't confirm.
good luck!
Old 04-20-2018, 11:29 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
ere may have been a few problems at one time but I believe they are ironed out.
That said, our HMM#1070 Wiseco/Cometic 107" Big Bore kits, boring your cyls, with ring gaps set, and rings installed on the pistons is still only $650.00.
Scott
__________________
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Maxton Mile World Record
4500 sq ft. facility
See us on Facebook.
Old 04-20-2018, 12:27 PM
memphisharley
Scott
so..i would need to send you a set of jugs. if so, i'll have to find a used set of jugs so I don't have any down time until I get ready to do the install.
can you pm me a list of what comes in your kit.
I will be contacting you soon to discuss this and other build questions/options.
thanks
Old 04-21-2018, 09:45 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,784 Likes on 3,300 Posts
Pretty sure Scott does a cam upgrade to the bore and pistons for $1k.. Yea then theres the heads and next thing you know you got quite the power band.....
Old 04-24-2018, 01:58 PM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
Last several of these S&S kits I have done come with everything gapped and checked from them. Always good practice to check yourself.
I set up 105 kits for about $400. Lots a different ways to build power.
Old 04-25-2018, 11:36 AM
Bowhunter61's Avatar
Bowhunter61
Bowhunter61 is offline
Very important point made right here
Old 04-26-2018, 06:04 AM
Hillsidecycle.com
Sponsor
thanks
Happy to help when you are ready!
Scott
Old 04-26-2018, 01:47 PM
memphisharley
Scott
thanks scott.
it was good speaking with you concerning my build. I look forward to working with you.
Old 04-26-2018, 06:36 PM
2009blackpearle's Avatar
2009blackpearle
2009blackpearle is offline
Default U cant go wrong with hillside
True professional work and advice. Just finished putting 107 cylinders stage 2 heads Andrews 57 cams 58mm throttle body from Scott. Did heat cycles last cpl days. Drove it to work today. Talk about smooth. Only been up to 2500 gently It pulls pretty good. Can’t imagine wide open. Just did new ve table run after work still have to load into the bike. Now to save up some pennies for Dyno tune in a cpl months.
Quick Reply: S&s 106 kit
