2014+ Touring Models This Section Is For Rushmore/2014+ Touring Models Only
fluid droplets on gas tank 2015 fltruse
Old 04-22-2018, 07:13 PM
motorsgt8's Avatar
motorsgt8
motorsgt8 is offline
Default fluid droplets on gas tank 2015 fltruse
I am getting fluid droplets on the right side of my tank when riding. It does not appear to be brake fluid. I had the master cover replaced and it is dry. When the dealer replaced it though the mechanic said he took apart the switch housing on that side and there was fluid inside there. His thought was that a cleaning product loosened up grease inside? It continues now even though he said he dried out as much as he could. I checked hoses for brake lines, radiator etc. all are dry. Any ideas what this could be? very frustrating, just glad its not dot 4 brake fluid.
Old 04-22-2018, 07:22 PM
68 XLCH's Avatar
68 XLCH
68 XLCH is offline
I don't follow the cleaning product loosening grease inside what the brake/hydralic reservoir? That doesn't make total sense to me. With all of the various cleaning, polishing products people use, i think that is a stretch.
I have heard over tightening the screws on the reservoir can cause leaking issues, does your model have water cooled heads, reservoir would be on that side.
Generally, if the engine oil is overfilled it can drip Down on the right side of the engine etc., but i guess it could blow up, never saw that tho, is it oil?
Just offering a few possibilities.
Old 04-22-2018, 08:01 PM
motorsgt8's Avatar
motorsgt8
Oil is halfway on dipstick, and I did not feel anything on the air filter. It has the stock cvo filter set up. It appears to be a thicker than water fluid. Does anyone know if by chance brake switch has grease in it and me be cracked and leaking?
Old 04-22-2018, 08:03 PM
motorsgt8's Avatar
motorsgt8
It is water cooled but the hoses appear to be dry.
Old 04-22-2018, 10:34 PM
Gwaxley's Avatar
Gwaxley
Gwaxley is offline
Its engine oil (crankcase ventilation) coming from the bottom of your air filter cover. Run your finger along the bottom of the AF cover and you should get some fresh Fluid Droplets.
https://www.hdforums.com/forum/new-r...r-cleaner.html
Old 04-23-2018, 06:39 AM
timbo141's Avatar
timbo141
timbo141 is offline
If it is not from blow by from the air filter area, maybe fork oil?
Check your fork caps on top, 1 3/8 I believe is the size.
Old 04-23-2018, 07:14 AM
jpooch00's Avatar
jpooch00
jpooch00 is offline
Personally, I wouldn't take ANYTHING said by a H-D "tech" very seriously, if I were you.
Find the problem yourself & fix it. That's the only way you'll know that it's actually fixed right and that no damage was done to your bike in the process.
Old 04-23-2018, 07:25 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
OP; Snap some pics of your tank so we can see where these drops are on the surface...top, bottom, front, back...
Old 04-25-2018, 08:17 AM
motorsgt8's Avatar
motorsgt8
Thanks for the help. Looks like GWAXLEY was correct. I took apart the air cleaner yesterday and there was oil on bottom of the air filter. Lowered the oil level and took it for a ride and no drops yet.
Thank you again.
Old 04-25-2018, 10:31 AM
hbsoldier3's Avatar
hbsoldier3
hbsoldier3 is offline
Thank you again.
Put an external breather kit on, and you can run your oil at the full mark.
Quick Reply: fluid droplets on gas tank 2015 fltruse
