Black '75 FXE Engine Case
Old 04-24-2018, 09:32 AM
Franklin Hanner's Avatar
Franklin Hanner
Franklin Hanner is offline
Stage II
Default Black '75 FXE Engine Case
I have an opportunity to pick up a '75 FXE for a decent price, but I noticed the engine case is black. To my understanding the only black engine cases were in the later years of shovelheads (e.g. Sturgis FXB). The numbers match the case, frame, and title, so it seems like it's the original case. I'm assuming someone painted this themselves?
Old 04-24-2018, 09:43 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,200 Likes on 1,477 Posts
Yes you are correct. Cases came in a natural finish. This one was stock except for the front master cylinder to brake hose and the battery side cover (that wasn't an option till a couiple years later).
Old 04-24-2018, 09:46 AM
Franklin Hanner
Stage II
How much work do you think it would require stripping the paint? Obviously I'd have to rip the engine completely apart, but what would be the best way to get the paint off and back to its original state?
Old 04-24-2018, 10:05 AM
panz4ever's Avatar
panz4ever
How about trying paint thinner first, or maybe Acetone or MEK. If none of that works then it means pulling the motor and taking off the carb (use rages to block off intakes). But I am thinking a good bead blaster could tape off most of the top end and exposed cone and motor sprocket side? Seems like something like bubble wrap and the packing wrap that reminds me of Seran wrap could ensure that nothing gets in your motor. Not a lot of surface area that is painted
Old 04-25-2018, 07:47 AM
Architect's Avatar
Architect
Architect is online now
Received 4,871 Likes on 2,538 Posts
The transmission case on my Flathead had been painted black somewhere in it's life. Real thick crap, very industrial. It took some time but using Aircraft Paint Remover I got it all off. Spray it on, let it bubble, then light scrub with a soft wire brush. Repeat as needed to get it all off.
Could it be done in the frame? How much patience do you have? If you pull the motor I bet it wouldn't be too bad to do on an engine stand and save yourself pulling the entire motor apart.
https://www.autobodytoolmart.com//kl...CABEgL_X_D_BwE
Old 04-25-2018, 09:08 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,403 Likes on 876 Posts
by the time you strip the motor down enough to remove all the paint, you're five bolts away from pulling it. and you don't have to worry about accidentally getting paint stripper on your frame. motor stands are easy to make:
Javed
Detailing
04-25-2018 09:23 PM
rattlebones
Exhaust System Topics
13
08-20-2017 06:47 PM
xcore
12-13-2014 05:29 PM
FlamedFXR
11-03-2009 07:58 AM
Pat
11
08-15-2005 01:13 AM
Quick Reply: Black '75 FXE Engine Case
