If you buy it you should do the following
Replace tires even if they look good
Replace wheel bearings
Replace gas
Change all fluids
Depending on the year and model of the bike have the cam tensioners changed or at least checked
Replace tires even if they look good You should check the date codes on the tires
Replace wheel bearings Why?
Bike sitting on the tires for 2 years and not moving is good enough reason for me to replace them
Same with the wheel bearings
Both are cheap insurance against your life
I would presume that it will have, or you will provide, a hot battery and some fresh gas. Might check the oil before cranking. I wouldn't care how good it looks, a bike that won't start is going to be mighty cheap. Just my $0.02...
I bought an ‘03 in ‘11, with 2090 miles. It was a trade in, I don’t know how long it sat. Changed fluids and tires, good to go. At 30k I had some base weeping so I had that fixed, and the SE Cam Chain Tensioner and Oil Pump upgrade. I have 43k now, no problems.
