Hertz MPX 165 or SV165/ST25 with SD800.4
Old 05-21-2018, 08:50 PM
maxburner's Avatar
maxburner
maxburner is offline
Default Hertz MPX 165 or SV165/ST25 with SD800.4
woukd like to hear everyone’s input on this. Fixing to install an SD800.4 and SD400.4. Currently have MPX 165’s in fairing with SS Picasso 540 and hcx 570’s in lids. Terrible I know. So do I keep the MPX’s in or switch to SV165/ST25? Already swapping HCX for VO 6x9 and B3. Just asking which hertz setup in fairing would sound best. Pretty sure I know the answer, just need to be pushed over the edge lol.
Old 05-21-2018, 08:59 PM
azlou66's Avatar
azlou66
azlou66 is offline
Install your new amps and tune them, listen to them and let your ears decide if you need new speakers. We find new **** that works by testing and testing and testing etal.
Old 05-21-2018, 09:01 PM
travelingypsye's Avatar
travelingypsye
travelingypsye is offline
Get a set of hcx 165's if you can find them. They are not near as crisp and don't have ear piercing highs like the milles. Now for the back, get a set of milles 6x9's. I know it sounds strange but the mille690.3 are just about the best 6x9 right now. The hcx 6x9's have screaming highs and the milles 165.3 have screaming highs but the hxc 165's and the mille 690.3 have a lot better, warmer sound.
Old 05-21-2018, 09:05 PM
azlou66's Avatar
azlou66
azlou66 is offline
Why not give the existing speakers a listen first then make that decision??.
Old 05-21-2018, 09:07 PM
maxburner's Avatar
maxburner
Interesting approach with the hcx’s. Let me think about that.
Old 05-21-2018, 09:08 PM
azlou66's Avatar
azlou66
azlou66 is offline
WADR I completely disagree DD VO M6x9's are a killer 6x9 with the power he is going to have.
Old 05-21-2018, 09:10 PM
haze324's Avatar
haze324
haze324 is offline
Max are you running a sound processor? You are going to need one to adjust the crossovers on that amp. Also if you have a sound processor (that you will need) then you can adjust and EQ each speaker whether you think they are too bright or perhaps need more highs, or tune the low end. I also think SV165 are way overpriced for what you get and would never run them.
Old 05-21-2018, 09:12 PM
maxburner's Avatar
maxburner
I heard the same thing on VO’s from several people which is why I switched. For the money, i felt I’d give them a chance
Old 05-21-2018, 09:13 PM
azlou66's Avatar
azlou66
azlou66 is offline
Max if you are jumping in the deep end which it sounds like you are why not run components up front like you plan for your bags?
Old 05-21-2018, 09:26 PM
maxburner's Avatar
maxburner
Yes I am planning to run the DSR1. As far as the SV’s go, I went ahead and got a set but havent got the STs yet. May run the B3 in the fairing as well as lids. Lot cheaper however I was a bit cautious because with b3s in fairing and lids because everyone says they are very bright.
Quick Reply: Hertz MPX 165 or SV165/ST25 with SD800.4
