LED headlight bulb from Fuel Moto
So, I installed the Fuel Moto FM-A6K Moto LED H4 headlight replacement bulb. $70.00
straight forward installation, it comes with four adapter plates and a spring. Does not come with instructions.
I used the adapter plate that matched the old bulbs back plate, it twist-locks into place, then put the bulb in just like the sticker. (No spring needed on my ‘97 FLHR.
It’s a little odd hearing a tiny fan operating when you turn on the ignition switch!
Stock bulb low beam
Stock- high beam
LED -low
LED - High beam
Stock bulb low beam
Stock- high beam
LED -low
LED - High beam
From the photo, it doesn’t appear to be much difference but the high beam is much brighter. Also the photo is only showing the light cast at about 15-18’ away into the door.
I’m going on a short road trip this week, I’ll probably be out after dark for a bit, so it’ll be interesting to see.
I may upgrade the spots too, but I rarely use the “ditch lights” so I’m not sure it’s worth it. I’m guessing there’s something available to convert them from the sealed beam units to LED bulbs.
