Why do these bikes sound different?
My friend has a stock 1998 Fatboy and I have a 1997 Fatboy. He has a CV carb. I have a Mikuni HSR 42. He has Vance and Hines short shots no baffles. I have short shots with slipons. Other than the exhaust why does his idle so much more like an old Harley? On his all you hear is that sweet popping sound.
both bikes are other wise stock. I think only difference is carb and I have screaming eagle box under seat. Before anyone says “it’s idled too low” even if I turn mine down it doesn’t sound like that.
Received 14,139 Likes
His bike has idle set too low. Your bike has idle set too high. The different exhausts and baffles will make a big difference.
I know you said the internals of the engine are stock on both, but it kind of sounds like he may have a different cam.
besides your idle being slightly high, you might be running a tad on the rich side, but only an afr meter can tell for sure, or an inspection of the spark plugs. It wouldn’t hurt to compare the plugs of both bikes out of curiosity
the different carburetors usually mostly affect throttle response and acceleration but it is possible to affect idle. Your bike almost sounds fuel injected
it is mostly the difference in exhaust and baffles though, as that is the primary thing that affects sound
