Where to buy Carlini's ?
Carlini buyer beware
I recently bought a pair of14* bars directly from Carlini. The bars were not balanced and it took over 10 days to convince them exchange them.
They told me they had trouble locating a pair of 14" bars, and I would need to wait. Then miraculously the next day my shipment was sent and the bars were balanced.
I took them to my installer and when I arrived to pick the bike up I realized that the bars were too long and they were actually 16* that Carlini sent me to replace the 14*s.
I believe they hoped I wouldn't check the height of the bars when they arrived and they were correct, the same way I dont measure a pair of shoes or a pair of jean's to make sure it is says what it says on the label.
I would advise that you seriously consider dealing with carlini. There are forums going back to 2011, 2014, and 2015 discussing problems with Carlini service.
The bars are good, but not what I wanted. Double check everything as Carlini are not to be trusted.
Maybe Carlini should consider local vendors to deal with their customer service issues.
Good luck.
Good luck.
Good luck.
Good luck.
Hi Desert Wolf,
Not balanced means that one side of the handle while was further back than the other.
This became apparent when you liaid the bars down on a flat surface facing toward you as if riding only 3 corners touched the surface and wobbled., the fourth corner was re aided approximately 3/8 of an inch.
Mario77746
09-11-2012 09:28 PM
