Micro amp mounting pics
What amp are you using?
Im in the middle of mounting a 2nd amp today. I was going to mount the JL MX280/4 on clutch side vertically (remember seeing pics posted in this forum awhile back), but found it fits perfectly in the space between BT bracket and radio on clutch side. Under the JM amp tray. Wedges in there nicely, friction fit.
just have to have out to adjust settings, then put back in.
Sorry..didnt think of that. I swapped head units and took cb out last week. If the length of the GZ isnt longer than the mx280, vertically should work, but might want a thin back plate, to use bottom screws. I was only able to use top 2 screws into bracket if i went vertically.
Disregard the wire mess, havent finished cleaning up wires. Im done for the day.
I cut the ring off already. I have my BT 355s tucked in there right now so would have to move them also. Hopefully cpbedor has some pics of a vertical mounted amp I can look at. Tailwind has also given me a couple of things to look out for.
Depending on the woof, that GZ will mount vertically in a matter of minutes with some industrial Velcro and 16" zip tie that goes around the amp and the bracket. If u have a larger magnet woof (bigger circumference) u can use a dremel multi tool and shave off the 3 higher bracket mount fasteners, drill the holes nice and purdy, the use flush mount 3/4 inch bolts which frees up another 1/8" for the amp to mount tight up against that pod eliminator bracket. It literally is a game of millimeters when ur not willing to put amps in bags or packs and I'm that guy.
T
T
