brake banjo fitting thread size?
Does anyone know what the thread size is for a 12mm banjo bolt? It is probably M11 by something. I tried to match it up at NAPA but they go from 10mm to 12mm. If there is a 7/16 extra fine thread it may match too.
Here's what I am trying to do. The front brake line looks like this now:
I want to add a brake light switch like this, and was going to tap the tee to make it fit:
Never mind - it's 7/16-24, and I ordered the tap
http://www.dragspecialties.com/products/?productId=475088&partNumber=BL77544CH
I suggest you find some Loctite 542 hydraulic sealer, you'll need it for that rig it'll never quit leaking without it. I use this stuff regular with custom brake & multiple fitting setups. Take a long hard look before you get busy drilling & tapping may not have enough meat left when done, maybe have an extra tee handy too.
Maybe this would be better? I am thinking I can drill and tap the 7/16 port deeper to eliminate the inverted flare seat...
https://www.jegs.com/i/Earls/361/972051/10002/-1
steveh326
04-19-2015 06:02 PM
