Brake Fluid Recall
I believe he's talking about the 2008-2011 brake failure recall. OP, go here and enter your VIN for the recall notice. I don't believe there is a deadline for safety recalls, though.
https://www.harley-davidson.com/us/e...e-recalls.html
Received 4,307 Likes
If you haven't had the ABS recall done I'd be making an appointment with the dealer. If moisture has gotten into the Hydraulic Control Unit for the ABS the valving in it could be corroding and that could case failure in the brakes. At least you have a recall, the "12's and '13's have the same module but not covered in the recall.
As stated, no expiration on safety recalls. What is referred to as campaigns versus recalls, those often have expirations. Since I change my own brake fluid and cycle the ABS with the Twin Scan II ABS, I’ll wait until some other time when I’ll just have a dealer do it to clear it out of the system.
My 08 has ABS....I read you can bleed as normal as long as you don't run the system dry and get air into the ABS control unit all is good. I believe this doesn't get all the fluid swapped out....but for a garage mechanic it will work.
or is it better to do this process, ride, then repeat to ensure getting all old fluid out?
I use a Mityvac...and go slow, take my time.
I gotta ask...
F150HD (09-02-2018)
It is better than nothing, but it is important to cycle the ABS. That is why we are reading about the folks that have gone in for the recall only to have the ABS module fail during the recall. Some folks bleed and then go out and purposely activate the ABS then bleed again.
I think what he's saying is that the little pistons or plungers inside the Hydraulic Control Unit (HCU) become seized up due to gunk from the old brake fluid. Apparently, they need to be "exercised" every so often so that they move back and forth by the ABS module. Here's what one looks like when it's gunked up:
Where is the HCU located on the bike? (08 Touring) thought I recalled it under a side cover...but haven't had them off in awhile.
