Lower fairing screws
Old Sep 27, 2018 | 08:52 PM
hardheaded's Avatar
hardheaded
Default Lower fairing screws
OK here's what's happened. trying to remove inner lower fairing to access radiators and the screws just spin.. Tried aliitle heat but i'm afraid of damaged to fairing. Any ideas on how to remove these things ? I can see the inserts just spinning in the lowers. These thing are tight. If i drill i may damage the fairing too.
Old Sep 30, 2018 | 11:54 AM
Stingray702's Avatar
Stingray702
I'm curious about this too. I need to remove my lower fairings too. I have a 2018 Ultra. There's nothing on the web explaining the removal of twin cooled lower fairings
Old Sep 30, 2018 | 01:24 PM
Grouser62's Avatar
Grouser62
As per service manual there is the upper clamp with two flange nuts and the lower clamp with one flange nut, would you not just need to get a grip on the nut? Maybe I don't understand
Old Sep 30, 2018 | 04:27 PM
Stingray702
there's two torque screws on the inside right above the clamp that hooks to the bottom of the engine guard. As I'm trying to take them out, the metal piece that they screw into spins. Another wonderful idea from the motor company.
Old Sep 30, 2018 | 04:29 PM
Stingray702
Here’s the area in question
This metal insert spin when you turn the screw
The screws
Old Oct 1, 2018 | 02:09 PM
hardheaded's Avatar
hardheaded
Yep, them are the screws If anyone has any ideas on how to remove these things ,speak up. What do the techs at the dealer do with this ? Certainly not replacing the lowers every time they destroy one taking it apart. Really a stupid design here. Why not have a bolt with a regular nut on this setup ?
Old Oct 1, 2018 | 06:34 PM
Stingray702
Truer words never spoken! I mustve cursed Harley many times yesterday for that RIDICULOUS design. I'll let you know what they do after I take the bike in. Total pain in the ***
Old Oct 2, 2018 | 08:10 AM
gigihurt's Avatar
gigihurt
That looks like a chicago nut. put an easy out in it and hold that.
Old Oct 2, 2018 | 10:39 AM
hardheaded's Avatar
hardheaded
There is a torx bolt in there that can't be removed.
Old Oct 2, 2018 | 11:00 AM
Ssitruc's Avatar
Ssitruc
I think what he meant was to put an easy-out in the back of the nut. The easy-out is left hand threaded, so when you start trying to loosen the torx bolt the easy-out will dig in and hold the nut still maybe... not a bad idea, if you can get it to bite before it hits the torx bolt.
